Proposed RFC on COLORRAMP Support (Bug 13 05)
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Tue Sep 27 17:16:07 EDT 2005
Bill,
Your example below works fine if you know the number of breaks ahead of
time, the big problem is that you do not. If you want to export a
control to the user to select the number of class breaks and then that
is applied to a classification algorithm which may return less than the
number requested, there is no way to deal with that under you scheme
that I can see.
Personally, I would like to move away from defining lots of classes for
this. The example mapfile was just how I had to do it now given the
tools that were available. If you classify into say 5 breaks and use the
ten classes I have defined you only get half way up the ramp or you have
to define multiple LAYER blocks each with a different number of breaks
and then turn on only the lay with the correct number of breaks, which
is kind of crazy.
I guess in general the big difference is whether you need to work with
continuous gradient ramps or discrete step ramps, with a variable number
of steps. In discrete steps each step has a value range and distribution
does not need to be linear.
You have spec'd a continuous value ramp, and forcing values into integer
step gets you part of the way there at the cost of the values. If you
implemented what you have spec'd and added the RAMPBREAKS or whatever as
an option all you would do code wise if convert the value to a integer
for your continuous ramp using a loop on the RAMPBREAKS and generate a
different styled legend maybe similar to my example in html. If the
RAMPBREAKS is absent then it is a continuous ramp. Maybe this should be
METHOD 'Discrete'.
-Steve W.
Bill Binko wrote:
> Stephen, I thought your example would be a good test case to show how you
> would get what you wanted using the ColorRamp as defined in the RFC.
> I'm sure it's not 100% what you'd like, but it's fairly close.
> It does make an assumption that the %% substitution works everywhere, and
> I'll make sure to add that to the RFC.  It also produces a legend that is
> a bit different from yours, in that it puts the demographic name on the
> first class, and then just the high/low values in the graded color bar
> (see http://mapserver.gis.umn.edu/bugs/attachment.cgi?id=324&action=view )
> Please use this as a starting point, and explain what won't work.  There
> may very well be some additional work on the legends that is needed, but I
> think the general need you're expressing is addressed.
> Bill
>   LAYER
>     NAME "zcta_thematic"
>     CONNECTIONTYPE postgis
>     CONNECTION "host=linus port=5432 dbname=census user=pgsql"
>     DATA "the_geom from (SELECT c.gid, c.the_geom, c.water, a.%demographic% as demog from %table% a,
>           sf3geo_zcta5 b, zcta c where c.state='%state%' and c.name=b.zcta5 and
>           a.stusab=b.stusab and a.logrecno=b.logrecno and b.stusab='%state%' and
>           b.sumlev='871'  ) as foo using srid=4326 using unique gid"
>     TYPE POLYGON
>     STATUS ON
>     PROJECTION
>       #"proj=latlong"
>       "init=epsg:4326"
>     END
>     CLASSITEM "water"
>     CLASS
>       NAME "Water"
>       EXPRESSION "t"
>       OUTLINECOLOR 102 102 204
>       COLOR 102 102 204
>     END
>     CLASS
>       NAME "%demog%"
>       EXPRESSION ([demog] > %break0% && [demog] <= %break1%)
>       OUTLINECOLOR 0 0 0
>       COLORRANGE
>         MINCOLOR 102 102 102
> 	MAXCOLOR 0 204 0
> 	MINVALUE %break0%
> 	MAXVALUE %break1%
> 	RANGEITEM 'demog'
>       END
>     END
>     CLASS
>       NAME " "
>       EXPRESSION ([demog] > %break1% && [demog] <= %break2%)
>       OUTLINECOLOR 0 0 0
>       COLORRANGE
>         MINCOLOR 0 204 0
>         MAXCOLOR 51 255 51
>         MINVALUE %break1%
>         MAXVALUE %break2%
>         RANGEITEM 'demog'
>       END
>     END
>     CLASS
>       NAME " "
>       EXPRESSION ([demog] > %break2% && [demog] <= %break3%)
>       OUTLINECOLOR 0 0 0
>       COLORRANGE
>         MINCOLOR 0 204 0
> 	MAXCOLOR 102 255 102
>         MINVALUE %break2%
>         MAXVALUE %break3%
>         RANGEITEM 'demog'
>       END
>     END
>     CLASS
>       NAME " "
>       EXPRESSION ([demog] > %break3% && [demog] <= %break4%)
>       OUTLINECOLOR 0 0 0
>       COLORRANGE
>         MINCOLOR 102 255 102
> 	MAXCOLOR 153 255 153
>         MINVALUE %break3%
>         MAXVALUE %break4%
>         RANGEITEM 'demog'
>       END
>     END
>     CLASS
>       NAME " "
>       EXPRESSION ([demog] > %break4% && [demog] <= %break5%)
>       OUTLINECOLOR 0 0 0
>       COLORRANGE
>         MINCOLOR 153 255 153
> 	MAXCOLOR 204 255 204
>         MINVALUE %break4%
>         MAXVALUE %break5%
>         RANGEITEM 'demog'
>       END
>     END
>     CLASS
>       NAME " "
>       EXPRESSION ([demog] > %break5% && [demog] <= %break6%)
>       OUTLINECOLOR 0 0 0
>       COLORRANGE
>         MINCOLOR 204 255 204
>         MAXCOLOR 255 294 294
>         MINVALUE %break5%
>         MAXVALUE %break6%
>         RANGEITEM 'demog'
>       END
>     END
>     CLASS
>       NAME " "
>       EXPRESSION ([demog] > %break6% && [demog] <= %break7%)
>       OUTLINECOLOR 0 0 0
>       COLORRANGE
>         MINCOLOR 255 294 294
> 	MAXCOLOR 255 153 153
>         MINVALUE %break6%
>         MAXVALUE %break7%
>         RANGEITEM 'demog'
>       END
>     END
>     CLASS
>       NAME " "
>       EXPRESSION ([demog] > %break7% && [demog] <= %break8%)
>       OUTLINECOLOR 0 0 0
>       COLORRANGE
>         MINCOLOR 255 153 153
>         MAXCOLOR 255 102 102
>         MINVALUE %break7%
>         MAXVALUE %break8%
>         RANGEITEM 'demog'
>       END
>     END
>     CLASS
>       NAME " "
>       EXPRESSION ([demog] > %break8% && [demog] <= %break9%)
>       OUTLINECOLOR 0 0 0
>       COLORRANGE
>         MINCOLOR 255 102 102
>         MAXCOLOR 255 51 51
>         MINVALUE %break8%
>         MAXVALUE %break9%
>         RANGEITEM 'demog'
>       END
>     END
>     CLASS
>       NAME " "
>       EXPRESSION ([demog] > %break9% && [demog] <= %break10%)
>       OUTLINECOLOR 0 0 0
>       COLORRANGE
>         MINCOLOR 255 51 51
>         MAXCOLOR 255 0 0
>         MINVALUE %break9%
>         MAXVALUE %break10%
>         RANGEITEM 'demog'
>       END
>     END
>   END
