Proposed RFC on COLORRAMP Support (Bug 13 05)
Ned Harding nharding at EXTENDTHEREACH.COM
Tue Sep 27 17:25:21 EDT 2005
Stephen Woodbridge Wrote:
>I can hardly argue with your impressive capabilities, but I have to believe
> that you have a fair amount of infrastructure backing up your thematic
maps
> that does not exist in mapserver today. I am not suggesting that we build
> it all into mapserver either.
My worries are about just how complicated it is to get breaks right and
weather that is best placed in MapServer.  The problem is that you can never
produce breaks with just the data you are sowing on a map, you have to look
at the whole dataset.  A good example of this is population density for
Manhattan.  If you are only looking at Manhattan you might make breaks from
low to high, but looking at the whole country it is obvious that they should
all be high.  In order to do this well, it almost certainly has to be a
pre-process.
For example, on our web site http://www.demographicsnow.com (which doesn't
use MapServer yet), we have over 7000 thematic variables at 12+ levels of
geography.  Every time we change data we have to run a preprocess on the
entire data set to calculate breaks for all the variables at all the levels
of geography.  Currently it takes 4-5 hours.
I guess this is a sensitive spot for me, because I have seen so many maps
produced with ESRI or MapInfo where people don't know how to calculate
breaks so the results are highly misleading.
That said, I have no problem about putting code in MapServer to calculate
breaks, but it should take into account the entire layer and not just the
current view and I wonder if that would be too slow for a typical map.
Personally I believe that the best way to generate breaks is to use a
logarithmic StdDev and have natural breaks for -2.5, -1.5, -.5, .5, 1.5 and
2.5 * StdDev + Mean.  The breaks don't have an even # of items in them, but
they convey the information in a very intuitive fashion.  If anyone wants
help implementing such a thing, I would be glad to help with advice or even
some code.
Maybe the best answer would be to create a separate API and system of
helping people set up good breaks with MapServer.
Sorry if this comes off like a rant, I have fought this battle in other
contexts before...
Ned.
-----Original Message-----
From: UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On
Behalf Of Stephen Woodbridge
Sent: Tuesday, September 27, 2005 12:46 PM
To: MAPSERVER-DEV at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-DEV] Proposed RFC on COLORRAMP Support (Bug 13
05)
Bill Binko wrote:
> On Tue, 27 Sep 2005, Ned Harding wrote:
>>Theming demographics is one of the most important things my company
>>does with a map, but I'm not sure why the need for RAMPBREAKS.  If you
>>are going to calculate your own ranges externally (which we do), it
>>seams like at best that is a syntax improvement on the current class
>>system, but it doesn't add any new functionality.  We haven't had any
>>problems displaying custom breaks in the existing system, since the class
let you do almost anything.
>>It seams to me the big advantage of color ramps is continuous coloring
>>(which there is no way currently to do), for which the scale would be
>>linear or logarithmic.  Not that I have a problem with the RAMPBREAKS
>>idea, but it does seams like feature creep.  I'd rather see something
>>get done than wait for a better solution for something we can already
>>do well enough.  It would be too bad if every RFC that comes up ends
>>up getting expanded to the point that people are afraid to propose them
because they get too big.
> Gentlemen,
> I agree that this feels like a bit of feature creep.  I can see why it
> would be useful, but I believe there are two ways to accomplish this
> with only the COLORRAMP changes currently in the RFC.
> One approach would simply be to manually create several CLASSes using
> the existing EXPRESSION keyword and the new COLORRAMP feature.  So, if
> you wanted a stop level at '10', you might have this:
> LAYER
>  CLASSITEM somefield
>  CLASS
>     EXPRESSION ([somefield] < 10)
>     COLORRANGE
>         MINVALUE 0
> 	MAXVALUE 10
> 	MINCOLOR 255 0 0 #red
> 	MAXCOLOR 255 255 0 #yellow
> 	RANGEITEM 'somefield'
> 	METHOD 'linear'
>     END
>   END
>  CLASS
>     EXPRESSION ([somefield] >= 10)
>     COLORRANGE
>         MINVALUE 10
>         MAXVALUE 20
>         MINCOLOR 255 255 0 #yellow
> 	MAXCOLOR 0 255 0 #green
>         METHOD 'linear'
>     END
>   END
> Another solution would be to use Mapscript to essentially do the same
> thing programatically.  I am sure one of the Mapscript gurus could put
> together a function (buildColorRampClasses for example) that
> essentially would allow this (in PHP):
> $theLayer = getTheLayerSomehow();
> $stops = array(0 => '255 0 0', 10 => '255 255 0', 20 => '0 255 0');
> buildColorRampClasses($theLayer, $stops, 'LINEAR', 'somefield');
> I believe the Mapscript class I described in the RFC would make this
> fairly simple.
> A final thought would be to create another METHOD that performed this.
> While I'm not necessarily opposed to that, a part of me worries about
> any method that would require additional keywords to do its work.
> Stephen, I hope this addresses your concerns.  If not, I'm willing to
> take another stab, or we can try it in a separate RFC.
> Thanks for the feedback,
> Bill
Ned,
that you have a fair amount of infrastructure backing up your thematic maps
that does not exist in mapserver today. I am not suggesting that we build it
Bill,
Thank you for the suggestion.
As a programmer I can munge the data to fit the tools, but what I am trying
to make sure that we have is the basics. And that other can use it also.
I can normalize my class values to integers, I do that today, but you loose
all the information about the values for mapsever legends. For example, look
at:
http://imaptools.com/~woodbri/thematic/thematic.cgi?name=ThemeMap&cmd=Map&de
bug=&location=MA&method=kmeans&numclasses=10&demographic=DP40063
by using the breaks you have real values for your legends instead of ordinal
number (0,1,2,3...). Notice I created these legends in html.
I would like to avoid using mapscript to dynamically generate some N number
of classes. It should not be required to do that for thematic maps. I should
be able to generate a thematic map with a simple LAYER definition using
PostGIS and get good legends. I can encapsulate all or most of the logic
needed in Perl or postgres functions.
Here is the mapfile for the link above:
http://imaptools.com/~woodbri/thematic/thematic.map
In fact if you look at the SQL you will notice a call to imt_classify()
which is converting the breaks into integer values based on the breaks that
are computed elsewhere so that the integers can be used to classify the map.
Summary, I guess I could work with normalizing the data and using a ramp
where I can set the min and max value as I can do that today, except %name%
substitution does not work in the current code. I do think it is not so good
that we are loosing the real values for the legends and would like to see
support for that.
-Steve W.
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20050927/a9a1fa6c/attachment.html
