Proposed RFC on COLORRAMP Support (Bug 13 05)
Bill Binko
bill at BINKO.NET
Tue Sep 27 18:19:06 EDT 2005
On Tue, 27 Sep 2005, Ned Harding wrote:
> Personally I believe that the best way to generate breaks is to use a
> logarithmic StdDev and have natural breaks for -2.5, -1.5, -.5, .5, 1.5 and
> 2.5 * StdDev + Mean. The breaks don't have an even # of items in them, but
> they convey the information in a very intuitive fashion. If anyone wants
> help implementing such a thing, I would be glad to help with advice or even
> some code.
> Maybe the best answer would be to create a separate API and system of
> helping people set up good breaks with MapServer.
I think one thing that I will do right now is to incorporate something
like the following into the RFC:
Multiple Mapping Methods
The system will allow new color mapping methods to be added with as little
effort as possible. If a new color mapping method uses only the keywords
defined by this RFC, it should be a simple as:
1) Implement a function with the signature
int mappingFn(colorRangeObj* range, shapeObj* shape, colorObj *color)
This function should use the shape and range parameters to determine the
shapes color, and modify the color parameter accordingly.
2) Choose a unique method name ('linear', 'logarithmic', 'discrete')
modify the method msMapColorRamp() to call its method when its method name
is found on a ColorRange definition.
Note: whether the msMapColorRamp() method uses if/then logic or dispatches
by function pointer can be determined later. For now, I believe the
simplest approach would be to move all of the mapping logic + all current
methods into a mapColorRange.c file.
Does that help?
Bill
