Proposed RFC on COLORRAMP Support (Bug 13 05)
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Tue Sep 27 18:11:48 EDT 2005
Bill Binko wrote:
> Steve,
> When you say, "You don't know how many breaks", perhaps I'm
> misunderstanding you. How do you get the break values into %breaks%? I
> was under the assumption that someone was choosing a drop-down that had
> strings with the breaks in them. Certainly if that's the case, you know
> how many there are at runtime.
You do not know at the time you create your mapfile.
> I know you don't like this answer, but this also seems to be easily doable
> in Mapscript.
> As for you idea of making this a "discrete" METHOD, I am OK with that. In
> fact, the INTERVALS keyword could be reused as follows:
> COLORRANGE
> METHOD 'linear'
> INTERVALS 10 #10 equals partitions
> END
> COLORRANGE
> METHOD 'discrete'
> INTERVALS 0 10 25 50 75 100 #exact value boundaries
> END
> If that were the case, this would not conflict with the other discussions
> we're having about where these things lived.
This would work for me if any value v:
0 <= v < 10 => color 1
10 <= v < 25 => color 2
etc.
and then you could do a legend like
[color1] "0 <= v < 10"
[color2] "10 <= v < 25"
etc.
and the intervals could be floats of ints.
-Steve W.
> Bill
> On Tue, 27 Sep 2005, Stephen Woodbridge wrote:
>>Bill,
>>Your example below works fine if you know the number of breaks ahead of
>>time, the big problem is that you do not. If you want to export a
>>control to the user to select the number of class breaks and then that
>>is applied to a classification algorithm which may return less than the
>>number requested, there is no way to deal with that under you scheme
>>that I can see.
>>Personally, I would like to move away from defining lots of classes for
>>this. The example mapfile was just how I had to do it now given the
>>tools that were available. If you classify into say 5 breaks and use the
>>ten classes I have defined you only get half way up the ramp or you have
>>to define multiple LAYER blocks each with a different number of breaks
>>and then turn on only the lay with the correct number of breaks, which
>>is kind of crazy.
>>I guess in general the big difference is whether you need to work with
>>continuous gradient ramps or discrete step ramps, with a variable number
>>of steps. In discrete steps each step has a value range and distribution
>>does not need to be linear.
>>You have spec'd a continuous value ramp, and forcing values into integer
>>step gets you part of the way there at the cost of the values. If you
>>implemented what you have spec'd and added the RAMPBREAKS or whatever as
>>an option all you would do code wise if convert the value to a integer
>>for your continuous ramp using a loop on the RAMPBREAKS and generate a
>>different styled legend maybe similar to my example in html. If the
>>RAMPBREAKS is absent then it is a continuous ramp. Maybe this should be
>>METHOD 'Discrete'.
>>-Steve W.
>>Bill Binko wrote:
>>>Stephen, I thought your example would be a good test case to show how you
>>>would get what you wanted using the ColorRamp as defined in the RFC.
>>>I'm sure it's not 100% what you'd like, but it's fairly close.
>>>It does make an assumption that the %% substitution works everywhere, and
>>>I'll make sure to add that to the RFC. It also produces a legend that is
>>>a bit different from yours, in that it puts the demographic name on the
>>>first class, and then just the high/low values in the graded color bar
>>>(see http://mapserver.gis.umn.edu/bugs/attachment.cgi?id=324&action=view )
>>>Please use this as a starting point, and explain what won't work. There
>>>may very well be some additional work on the legends that is needed, but I
>>>think the general need you're expressing is addressed.
>>>Bill
>>> LAYER
>>> NAME "zcta_thematic"
>>> CONNECTIONTYPE postgis
>>> CONNECTION "host=linus port=5432 dbname=census user=pgsql"
>>> DATA "the_geom from (SELECT c.gid, c.the_geom, c.water, a.%demographic% as demog from %table% a,
>>> sf3geo_zcta5 b, zcta c where c.state='%state%' and c.name=b.zcta5 and
>>> a.stusab=b.stusab and a.logrecno=b.logrecno and b.stusab='%state%' and
>>> b.sumlev='871' ) as foo using srid=4326 using unique gid"
>>> TYPE POLYGON
>>> STATUS ON
>>> PROJECTION
>>> #"proj=latlong"
>>> "init=epsg:4326"
>>> END
>>> CLASSITEM "water"
>>> CLASS
>>> NAME "Water"
>>> EXPRESSION "t"
>>> OUTLINECOLOR 102 102 204
>>> COLOR 102 102 204
>>> END
>>> CLASS
>>> NAME "%demog%"
>>> EXPRESSION ([demog] > %break0% && [demog] <= %break1%)
>>> OUTLINECOLOR 0 0 0
>>> COLORRANGE
>>> MINCOLOR 102 102 102
>>> MAXCOLOR 0 204 0
>>> MINVALUE %break0%
>>> MAXVALUE %break1%
>>> RANGEITEM 'demog'
>>> END
>>> END
>>> CLASS
>>> NAME " "
>>> EXPRESSION ([demog] > %break1% && [demog] <= %break2%)
>>> OUTLINECOLOR 0 0 0
>>> COLORRANGE
>>> MINCOLOR 0 204 0
>>> MAXCOLOR 51 255 51
>>> MINVALUE %break1%
>>> MAXVALUE %break2%
>>> RANGEITEM 'demog'
>>> END
>>> END
>>> CLASS
>>> NAME " "
>>> EXPRESSION ([demog] > %break2% && [demog] <= %break3%)
>>> OUTLINECOLOR 0 0 0
>>> COLORRANGE
>>> MINCOLOR 0 204 0
>>> MAXCOLOR 102 255 102
>>> MINVALUE %break2%
>>> MAXVALUE %break3%
>>> RANGEITEM 'demog'
>>> END
>>> END
>>> CLASS
>>> NAME " "
>>> EXPRESSION ([demog] > %break3% && [demog] <= %break4%)
>>> OUTLINECOLOR 0 0 0
>>> COLORRANGE
>>> MINCOLOR 102 255 102
>>> MAXCOLOR 153 255 153
>>> MINVALUE %break3%
>>> MAXVALUE %break4%
>>> RANGEITEM 'demog'
>>> END
>>> END
>>> CLASS
>>> NAME " "
>>> EXPRESSION ([demog] > %break4% && [demog] <= %break5%)
>>> OUTLINECOLOR 0 0 0
>>> COLORRANGE
>>> MINCOLOR 153 255 153
>>> MAXCOLOR 204 255 204
>>> MINVALUE %break4%
>>> MAXVALUE %break5%
>>> RANGEITEM 'demog'
>>> END
>>> END
>>> CLASS
>>> NAME " "
>>> EXPRESSION ([demog] > %break5% && [demog] <= %break6%)
>>> OUTLINECOLOR 0 0 0
>>> COLORRANGE
>>> MINCOLOR 204 255 204
>>> MAXCOLOR 255 294 294
>>> MINVALUE %break5%
>>> MAXVALUE %break6%
>>> RANGEITEM 'demog'
>>> END
>>> END
>>> CLASS
>>> NAME " "
>>> EXPRESSION ([demog] > %break6% && [demog] <= %break7%)
>>> OUTLINECOLOR 0 0 0
>>> COLORRANGE
>>> MINCOLOR 255 294 294
>>> MAXCOLOR 255 153 153
>>> MINVALUE %break6%
>>> MAXVALUE %break7%
>>> RANGEITEM 'demog'
>>> END
>>> END
>>> CLASS
>>> NAME " "
>>> EXPRESSION ([demog] > %break7% && [demog] <= %break8%)
>>> OUTLINECOLOR 0 0 0
>>> COLORRANGE
>>> MINCOLOR 255 153 153
>>> MAXCOLOR 255 102 102
>>> MINVALUE %break7%
>>> MAXVALUE %break8%
>>> RANGEITEM 'demog'
>>> END
>>> END
>>> CLASS
>>> NAME " "
>>> EXPRESSION ([demog] > %break8% && [demog] <= %break9%)
>>> OUTLINECOLOR 0 0 0
>>> COLORRANGE
>>> MINCOLOR 255 102 102
>>> MAXCOLOR 255 51 51
>>> MINVALUE %break8%
>>> MAXVALUE %break9%
>>> RANGEITEM 'demog'
>>> END
>>> END
>>> CLASS
>>> NAME " "
>>> EXPRESSION ([demog] > %break9% && [demog] <= %break10%)
>>> OUTLINECOLOR 0 0 0
>>> COLORRANGE
>>> MINCOLOR 255 51 51
>>> MAXCOLOR 255 0 0
>>> MINVALUE %break9%
>>> MAXVALUE %break10%
>>> RANGEITEM 'demog'
>>> END
>>> END
>>> END
