Mapserver 4.6.1 configure fails ("test: unknown operator ==" - line 9975)
Frank Warmerdam warmerdam at POBOX.COM
Thu Sep 29 09:28:12 EDT 2005
On 9/29/05, Havard Tveite <havard.tveite at umb.no> wrote:
> On Solaris 2.7, Mapserver 4.6.1 configure fail with the
> following error message:
> The problem is line 9975:
> "if test "$enable_point_z_m" == "yes" ; then"
Havard,
I believe this is one of those things that works with /bin/bash
(used on Linux) but not on the traditional bourne shell used on
Solaris, freebsd, etc.   I have created a bug for this problem and will
fix it in 4.6 and 4.7.
  http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1485
Your change directly in configure is fine as a workaround.
Best regards,
