PHP/Mapscript 4.8.3 crash
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Fri Apr 7 09:30:31 EDT 2006
Hi Assefa,
I have attached my testcase in bug report 1745, hope you can reproduce:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1745
Best regards,
Bart
Yewondwossen Assefa wrote:
> Bart,
> Could not get the crah using my tests data with 4.8.3 and current cvs.
> I have a pretty simple query template ([shpxy xh="(" yf=")"], set on
> the layer that is queried.
> If there is a way for me to reproduce it wuth you set of data/query,
> I can look into it.
> Layer,
> Bart van den Eijnden (OSGIS) wrote:
>> Hi list,
>> I am getting a crash of php on Windows when trying to set the
>> template of a class after processQueryTemplate has been called.
>> If I leave out the processQueryTemplate call the line which sets the
>> class template does not crash.
>> Is anybody able to confirm this behaviour? Am I trying something
>> "illegal"? Btw the code comes from Chameleon's MapTips widget.
>> <?php
>> dl('php_mapscript_48.dll');
>> $oMap = ms_newmapobj(dirname(__FILE__)."/test.map");
>> $oLayer = $oMap->getLayerByName('werkzaamheden');
>> @$oLayer->queryByRect( $oMap->extent );
>> $szCoords = $oMap->processQueryTemplate( array(), false );
>> for ($i=0; $i<$oLayer->numclasses; $i++)
>> $oClass = $oLayer->getClass( $i );
>> // crashes here if processQueryTemplate is called before
>> $oClass->set( "template", 'blank.html' );
>> Best regards,
>> Bart
OSGIS, Open Source GIS
http://www.osgis.nl
