Proposal to add Steve Woodbridge to the TSC
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Apr 13 16:21:37 EDT 2006
I want to thank Sean for the proposal and all of you for your votes of
confidence. I would be pleased to serve on the TSC if that is what you
decide. I also understand Daniel's concern about dissolving the
technical strength of the TSC. While I have not contributed code, I have
reviewed code, discussed design algorithms and written my own mapserver,
that I abandoned for UMN Mapserver. I have 30+ years of development,
development management, QA and process management in my history, but I
will not bore you with the details. I will continue to do what I do for
mapserver regardless and will probably do more if approved just because
of the weight of responsibility :)
I feel honored just be being considered.
Best regards to all,
-Steve W
Sean Gillies wrote:
> Hi all,
> For as long as I've been involved with MapServer, Steve Woodbridge has
> been a contributor to discussions not only on MapServer usage, but also
> on project architecture, governance, and direction. I've appreciated
> his insights, and would like for us to encourage and empower Steve by
> giving him a position on MapServer's technical steering committee. In
> accordance with our rules, I propose that we add Steve Woodbridge as a
> TSC member, and cast my +1 vote.
> Sean
> Sean Gillies
> http://zcologia.com
