RFC 14 Implementation Question
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Fri Apr 14 00:16:37 EDT 2006
Um, one last thing. Starting the position enumeration at, say, 20 means we have to do something when writing mapfile. Recall that the enumerations have a companion arrat of strings that form a simple lookup table. Those will be out of sync. I'm wondering if we might do something like in map.h:
#define MS_POSITIONS_BASE_VALUE 20
enum MS_POSITIONS {MS_UL=MS_POSITIONS_INIT_VALUE, MS_LR, MS_UR, MS_LL, MS_CR, MS_CL, MS_UC, MS_LC, MS_CC, MS_AUTO, MS_XY, MS_FOLLOW};
So then in the mapfile writing code we'd offset the stored position by MS_POSITIONS_BASE_VALUE:
fprintf(stream, " %sPOSITION %s\n", tab, msPositions[label->position-MS_POSITIONS_BASE_VALUE]);
and so on for any parameters that use the positions enumeration.
Perhaps there's a better way though so I'm open to suggestions.
Steve
