Proposing to call setlocale( LC_ALL, "C" ) in msSetup()
Frank Warmerdam
warmerdam at POBOX.COM
Fri Apr 28 12:13:13 EDT 2006
Szekeres Tamás wrote:
> I'm not sure if this problem is restricted to the float number conversion,
> so replacing atof, strtod etc. to the locale independent
> implementations would be great, but i don't think if it is enough.
> And we should also take the subsequent libraries into consideration
> with the locale dependency stuff.
Tamas,
I would note we have *alot* of code doing printf style output of XML,
GML, etc using the default numeric formatting. It would be quite a job
to replace all that. Much harder than replacing atof() calls for instance.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
