How to do a buffer with CGI command
Lisbeth Mavárez Sandoval
lisbeth.mavarez at KIBERNO.COM
Fri Apr 28 17:20:11 EDT 2006
Hi Steve,
Thanks for your answer.
I don't know how to do the buffer-like queries with the CGI.
Could you give an example?
I have been trying to do it, but I'm not sure if it is working
correctly. This is my URL:
http://myserver/cgi-bin/mapserv.exe?map=C:\mypath\mymap.map&mode=ITEMQUE
RYMAP&MAPXY=66.86
10.49&BUFFER=100&MAPEXT=shape&qlayer=mylayer&qitem=id&qstring=501
Could you check it?
Thanks,
Lisbeth Mavárez
Maracaibo - Venezuela
-----Mensaje original-----
De: UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU]
En nombre de Steve Lime
Enviado el: Jueves, 27 de Abril de 2006 11:31 p.m.
Para: MAPSERVER-DEV at LISTS.UMN.EDU
Asunto: Re: [UMN_MAPSERVER-DEV] How to do a buffer with CGI command
Hi there: The bad news is that you can't do a buffer from the CGI. There
is no processing directive for vector data like there is for raster.
However, you can do buffers from within MapScript. So if that's a
feature you really need (you can do buffer-like queries with the CGI),
that is, drawing a buffered feature then you must use MapScript.
Steve
>>> Lisbeth Mavárez Sandoval <lisbeth.mavarez at KIBERNO.COM> 04/27/06 3:26
PM >>>
I´m just learning about MapServer. I´m not understand how to do a buffer
in URL of CGI command.
Could somebody help me please?
Very thanks,
Lisbeth Mavárez
