Multiple user problem -- C# MapScript Web Application (Is
mapserver thread safe?)
Benedikt Rothe
umn-ms at HYDROTEC.DE
Wed Aug 9 09:11:38 EDT 2006
Hi
Sorry Tamas. I'm affraid I won't be helpfull.
> How the global synchronization affect the performance of your
> application in a multiuser environment?
I couldn't test the influence of "synchronized", because of the crashes
without synchronizing.
(I didn't make a test without parallel requests. Wasn't usefull for me)
Additionally I'm quite shure, that the "Maps per Minutes"-Index
is (almost?) not influenced on a single CPU-machine. I expect that
lock-acquire is *much* cheaper, than map-drawing.
On Multi-CPU things become bad!
Therfore I never thought of "synchroized" as a solution but a workaround.
> I afraid this kind of protection cannot be utilized easily for ASP.NET
> since the host process
> may load and execute multiple separate application domains.
"application domains"? puh ...
I never really wrote a line C#. What about this?:
class MyClass
static readonly object globalLock = new object();
public void anInstanceMethod () {
lock (globalLock ) {
umnMap.draw();
Has every application domain it's own static members?
> However i am keen to implement such functionality at the SWIG
> interface level as an alternative to the USE_THREAD approach.
What a pitty! I loved your enthusiasm to provide a "real" solution :-)
I absolutely agree, that this issue will become very important for C#,
Java and
for Multiprocessor-machines.
Additionaly: I found Ned Harding's approach intersting. This is what Esri
did with ArcView-IMS an MO-IMS.
Ciao
Benedikt
UMN MapServer Developers List <MAPSERVER-DEV at LISTS.UMN.EDU> schrieb am
09.08.2006 10:40:21:
> Benedikt,
> Tamas
> 2006/8/9, Benedikt Rothe <umn-ms at hydrotec.de>:
> > Tamas, Umberto
> > Umberto wrote about good experience with Mapserver-Multithreading in
Java.
> > This is not my experience. In our "Mapserver-Servlet" we had to use a
global
> > synchronizing around
> > mapserver-calls (i.e. disabling multithreading) to avoid crashes.
> > Benedikt
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20060809/e1856582/attachment.html
