PostGIS Connector Bug 1536 Fix
Andreas Albarello
andreas.albarello at TERRITORIUMONLINE.COM
Fri Aug 18 06:41:46 EDT 2006
Tamas Szekeres wrote:
> I'm not so far with how the fix was made actually, but i'm a bit
> uncertain whether
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1549
> was also handled.
> How should we quote the names in the map file properly?
Tamas and all the folks out there,
I've recently come up with a fix for
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1549 by changing the
regular expressions used inside the mapfile lexer for parsing strings
and regular expressions.
This way I'm now able to escape quotes inside strings and slashes inside
regular expressions by doubling them. I've taken this approach as
escaping with backslashes would break a vast majority of Windows
mapfiles out there using the backslash as path delimiter and potentially
having therefore backslashes as last character of some strings (e.g.
SHAPEPATH "C:\data\")
I've however not addressed some related issues like accordingly doubling
quotes in attribute strings coming from shapefiles or other data source
(for proper comparison inside mapfile expressions) or checking whether
the mapfile writer would need some adjustments once this fix is applied.
If however, despite the fact that this fix is not actually complete,
someone is interested in having a look at it, I'm ready to submit it to
bugzilla.
Best regards,
Andreas Albarello
Analysis & SW Development
Territorium Online srl/GmbH
Via Buozzi Str. 12
I 39100 Bolzano/Bozen
Phone: +39 0471 068611
Fax: +39 0471 068619
email: andreas.albarello at territoriumonline.com
web: http://www.territoriumonline.com
