MSAutotest WxS on windows
Frank Warmerdam
warmerdam at POBOX.COM
Mon Aug 28 18:16:13 EDT 2006
Frank Warmerdam wrote:
> Normand Savard wrote:
>>> o windows does expoential notation with three digits instead of two.
>> I think we have no choice here to have two sets of expected results:
>> one for Windows and one for Unix. Unless we use an external program
>> that will compare files and check for numbers precisions like ndiff.
> Norman,
> We already have special processing when [RESULT_DEVERSION] is used
> to strip MapServer version information out of the capabilities. I
> can extend this processing to also change strings of the form
> 'e+0nn"' to 'e+nn"'. This should resolve most of this particular
> issue. I'll give this a try and let you know.
Normand,
I have modified the test suite to "fix up" the exponents when RESULT_DEVERSION
is applied. Let me know how you do on the rest of the issues.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
