MapServer 4.10.0-beta2 Released
Daniel Morissette dmorissette at MAPGEARS.COM
Tue Aug 29 01:25:35 EDT 2006
Oh, I forgot to attach the list of fixes since beta1. Here it is:
Version 4.10.0-beta2 (2006-08-28)
- Applied patch supplied by Vilson Farias for extra commas with imagemap
   output (bug 760).
- Fixed possible heap overflow with oversized POST requests (bug 1885)
- Set ./lib and ./include properly for MING support (bug 1866)
- More robust library checking on OSX (bug 1867)
- Removed mpatrol support (use valgrind instead for something
   similar and less intrusive).  (bug 1883)
- Added mapserver compilation flags to the SWIG c# command line (bug 1881)
- Fix OSX shared library options for PHP (bug 1877).
- Added setSymbolByName to styleObj for the SWIG mapscript in order to
   set both the symbol and the symbolname members (bug 1835)
- Generate ogc filters now outputs the ocg name space (bug 1863)
- Don't return a WCS ref in WMS DescribeLayer responses when layer type is
   CONNECTIONTYPE WMS (cascaded WMS layers not supported for WCS) (bug 1874)
- Correct partly the problem of translating regex to ogc:Literal (bug 1644)
- schemas.opengeospatial.net has been shutdown, use schemas.opengis.net
   instead as the default schema repository for OGC services (bug 1873)
- MIGRATION_GUIDE.TXT has been created to document backwards incompatible
   changes between 4.8 and 4.10
- Modify mapgd.c to use MS_NINT_GENERIC to avoid rounding issues. (bug 1716)
- added --disable-fast-nint configure directive (bug 1716)
- Fixed php_mapscript Windows build that was broken in beta1 (bug 1872)
- Supported <propertyname> tag in SLD label (Bug 1857)
- Use the label element in the ColorMapEntry for the raster symbolizer
   (Bug 1844)
- Adding Geos functions to php mapscript (bug 1327)
- Added a type cast to msio.i so as to eliminate the warning with the
   SWIG unix/osx builds
- Fixed csharp/Makefile.in for supporting the OSX builds and creating
   the platform dependent mapscript_csharp.dll.config file.
- Fixed error in detection of libpdf.sl in configure.in (bug 1868).
Daniel Morissette wrote:
> Hi All,
> MapServer 4.10.0-beta2 is now available and can be downloaded at
> http://mapserver.gis.umn.edu/download/beta
> As usual please report issues via bugzilla, and for those interested in
> the complete 4.10 release plan, see
> http://mapserver.gis.umn.edu/development/release_plans/mapserver_4_10/
> Daniel
Daniel Morissette
http://www.mapgears.com/
