Mapserver compilation flags should be added to the SWIG
command line
Tamas Szekeres
szekerest at GMAIL.COM
Wed Aug 30 16:16:50 EDT 2006
Umberto,
I guess your proposal was to replace the affected functions from the
interface files to the core mapserver code, correct me if I am wrong.
But I still can't understand what's the problem with adding the
preprocessor defines to the SWIG command line. It requires to change
only a line in the makefile.
Tamas
2006/8/30, Umberto Nicoletti <umberto.nicoletti at gmail.com>:
> Hi Steve,
> While doing the usual house keeping before 4.10 gets out I have looked
> at the source of the swig interface files and found that they contain
> preprocessor defines (#ifdef USE_GEOS for example).
> Most of the mapscript laguages will ignore these defines because swig
> is not passed the list of options built by configure. Java mapscript
> used to pass the list to swig, but this feature was removed a long
> time ago because Sean opted for removing the preprocessor defines from
> the swig interface files to keep them tidier.
> C# mapscript at this point is the only laguage still passing defines to swig.
> Perl, Ruby and Python invoke swig without passing the defines; also,
> in the case of Perl and Python swig must be run manually by the user
> (by typing the right command in the shell).
> Now since most mapscript will ignore those preprocessor defines we are
> facing a potentially critical issue and, in the case of GEOS,
> mapscript won't use some GEOS functions.
> Other possible errors could be memory errors due to the use of non
> initialized variables (this is the case of POINT_Z_M).
> I have reviewed the swig interface files and found these possibly
> harmful defines:
> swiginc/image.i:#if GD2_VERS > 1
> Not sure about this one, maybe it is right. Dunno where GD2_VERS is defined.
> swiginc/image.i:#ifdef USE_GD_GIF
> swiginc/image.i:#ifdef USE_GD_PNG
> swiginc/image.i:#ifdef USE_GD_JPEG
> swiginc/image.i:#ifdef USE_GD_WBMP
> These were added by Sean in July 04 and should be removed, I guess.
> They only affect TCL.
> swiginc/point.i:#ifdef USE_POINT_Z_M
> These are *rarely* used and they are not a real problem, at least for
> 4.10. If used they crash Java mapscript for sure.
> swiginc/shape.i:#ifdef USE_GEOS
> These were added by sdlime on his lates rework of geos code this june.
> They should be moved out of the swig interface file into the c code of mapserver
> I hope I made myself clear,
> Umberto
> On 8/28/06, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> > Confused, what's the desired fix?
> > >>> Umberto Nicoletti <umberto.nicoletti at GMAIL.COM> 8/28/2006 10:47:08
> > AM >>>
> > I have posted a similar mail today (search for Defines in swig
> > interface files in the subject) . Tamas, sorry for the double posting,
> > I missed this one.
> > I appear to recall that it was once agreed that swig interface files
> > should not have defines in them, but I at the moment the only
> > reference I found is here:
> > http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=895#c2
> > (end of first para)
> > Sean Gillies probably knows better.
> > At this point C# is the only language that has 100% correct
> > compilation today. Java mapscript had the flags passed to swig, but
> > they were removed a long time ago.
> > Other laguages like ruby and python require the user to generate the
> > interface by running swig by hand. This makes it much difficult to
> > pass defines to swig as the user should have to copy them from the
> > Makefile or alternatively we should provide and mantain Makefiles for
> > all mapscripts.
> > This is the list of defines (still) in the swig interface files:
> > Not sure about this one, maybe it is right.....
> > These were added by Sean in July 04.
> > These are rarely used and they are not a real problem, at least for
> > 4.10
> > I can try to take care of the defines in image.i and maybe steve of
> > those in shape.i, but I dunno if I'm going or if we should do it for
> > for 4.10?
> > Umberto
> > On 8/28/06, Daniel Morissette <dmorissette at mapgears.com> wrote:
> > > Tamas Szekeres wrote:
> > > > Folks,
> > > > Currently most of the SWIG bindings does not add mapserver
> > compilation
> > > > flags to the
> > > > SWIG command line and therefore the interface might not be
> > generated
> > > > properly.
> > > > For example missing -DUSE_POINT_Z_M will prevent from generating z
> > and m
> > > > members
> > > > for pointObj etc.
> > > > I've added a bug for this issue:
> > > > http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1881
> > > > And fixed for C#
> > > Does something need to be done for this for the other wrappers?
> > There
> > > used to be a 'mapscriptvars' file with all the compile flags used by
> > the
> > > Perl Makefile. Is this not used by the other bindings?
> > > Daniel
> > > Daniel Morissette
> > > http://www.mapgears.com/
