java mapscript map annotations
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Thu Aug 31 10:59:00 EDT 2006
On 8/31/06, mikiet <mike.talbutt at dottedeyes.com> wrote:
> Hi there,
> I am new to mapserver and am using java mapscript to create a new
> application. I have found documentation on java mapscript prettu hard to
> come by, however have managerd to get most of my application up and running
> pretty quickly.
> Hoever I've fallen into problems annotation the map. My application needs to
> be able to annonate the map with rectangles, circles and ellipses.
> rectangles were easy, I simply created a new lineObj and added the points
> for my rectangle, create a shapeObj adding my lineObj to it and then added
> my shape to the layer as an feature.
> Hoever how would I do this with a circle ?, in previose examples when I have
> rendered points on a map as circles I have created a circle symbol in my
> .sym file and applied that symbol to the features, however in my application
> when I draw the circle I need to be able to specify the radius. Also I would
> prefer the circle annonation to actually be a circle rather then a point
> using a circle symbol to render it.
Doesn't setting the symbol size accomplish exactly this?
Umberto
> Any help or pointers to documentation would be greatfully appreciated
> View this message in context: http://www.nabble.com/java-mapscript-map-annotations-tf2195520.html#a6075867
> Sent from the Mapserver - Dev forum at Nabble.com.
