Why not always DEBUG=MSDEBUG?
Daniel Morissette dmorissette at MAPGEARS.COM
Mon Dec 11 11:07:51 EST 2006
Frank Warmerdam wrote:
> Can anyone think of a reason we wouldn't always enable use of debugging
> output
> in mapserver?
Here are the two reasons I can think of:
1- I am not 100% sure that all msDebug() calls are protected by an
if(...debug) test. This would need to be verified prior to making your
proposed change
2- Under IIS, stderr is merged with stdout so msDebug() just doesn't
work there and enabling debug in that environment can (and often does!)
result in malformed headers or corrupt output.
> It is a great frustration to me that many people with binary
> MapServer builds do not have MSDEBUG support enabled.  I'd like permission
> to make this non-optional.
> I'm suggesting the --enable-debug / --disable-debug switches on the unix
> configure would just control -g.
That would probably be a good idea as long as we also take care of the
issues above.
BTW, bugs 709, 1333 and 1783 relate to this directly or indirectly and I
had included a "cleanup of LOG/DEBUG output mechanisms" item covering
them in the 5.0 roadmap.
Daniel
Daniel Morissette
http://www.mapgears.com/
