Why not always DEBUG=MSDEBUG?
Frank Warmerdam
warmerdam at POBOX.COM
Mon Dec 11 12:39:29 EST 2006
Daniel Morissette wrote:
> Frank Warmerdam wrote:
>> Can anyone think of a reason we wouldn't always enable use of
>> debugging output
>> in mapserver?
> Here are the two reasons I can think of:
> 1- I am not 100% sure that all msDebug() calls are protected by an
> if(...debug) test. This would need to be verified prior to making your
> proposed change
> 2- Under IIS, stderr is merged with stdout so msDebug() just doesn't
> work there and enabling debug in that environment can (and often does!)
> result in malformed headers or corrupt output.
Daniel,
OK, I'm going to withdrawn the simple approach for now, and will try
to propose something a bit more comprehensive based that also addresses
use of MS_ERRORFILE and the LOG directive (is there such a thing? I
don't know anything about it).
> That would probably be a good idea as long as we also take care of the
> issues above.
> BTW, bugs 709, 1333 and 1783 relate to this directly or indirectly and I
> had included a "cleanup of LOG/DEBUG output mechanisms" item covering
> them in the 5.0 roadmap.
I have ensured I'm attached to all of these.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
