Hi list, just reporting back that the asterisk problem (*************) for null values in the GML could be solved by using OGR to connect to the shapefiles instead of using the Mapserver native shapefile connector. Best regards, Bart -- Bart van den Eijnden OSGIS, Open Source GIS http://www.osgis.nl
