MapServer "version" info missing in 4.8
Frank Warmerdam
warmerdam at POBOX.COM
Thu Feb 2 14:58:38 EST 2006
Steve,
I see that in December you removed the MapServer
version information from HTML processed output by
commenting out the following line in mapserv.c:
/* msIO_printf("<!-- %s -->\n", msGetVersion()); */
Was this done since the result was not valid XML, when
you did the upgrade to support XML output?
I think this is pretty useful information to include in the
output. Would it be OK to re-enable it if the output is
HTML? Or perhaps generate a meta tag or
something similar?
I gather there is a [VERSION] replacement item, so folks
can decide to include the version info if they want. But
for debugging purposes it would be awefully handy to include
it by default.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
