Questions about extents and projections
Sean Gillies
sgillies at FRII.COM
Thu Feb 2 17:15:19 EST 2006
On Jan 31, 2006, at 2:33 PM, Brian Peschel wrote:
> I have taking the 4.6.2 version of MapServer and (using the makefile)
> building as a C library and linking into a custom application I
> have. I am
> using the MapServer code to generate JPG images.
> I am trying to create a cube of images that I can then stitch
> together.
> Something like:
> ABC
> DEF
> GHI
> Every image should have the same number of pixels, so I am
> overriding the
> map file by resetting the value in the loaded mapObj ojbect by:
> map->height = 354;
> map->width = 609;
> I know the lat/lons of every corner of each image, so I am
> overriding the
> map file by resetting the extent in the loaded mapObj object by:
> map->extent.minx = corner[SW].x();
> map->extent.maxx = corner[SE].x();
> map->extent.miny = corner[NW].y();
> map->extent.maxy = corner[SW].y();
> I then create the 9 images. If I then paste the 9 images together
> I would
> expect a seamless connection (labels might be messed up). I am not
> seeing
> this. The stitching is working on the same row. A + B + C looks
> good, D +
> E + F looks good and G + H + I looks good. Hoever the columns are
> wrong. A
> + D + G has overlap on the top an bottom of the image.
> I used to do this manually (using GD) by converting the lat/lon
> coordinates
> to pixels and calling GD methods to draw lines. Comparing my older
> images
> to the new MapServer images, it looks like the image is being
> stretched in
> both Y directions (miny and maxy are both changing).
> Based on the tutorial I worked through and O'Reily's book, I
> expected the
> features draw to be 'stretched' to match the number of pixels I
> requested.
> I at least expected one of the y values to be correct, not both of
> them.
> Any ideas here? I am not actually using any projection in my map
> file. I
> am requesting lat/lon in the same projection a the shp file. There
> are no
> PROJECTION blocks in my map file at all.
> I can provide a copy of my map file and C code if it will help. I
> can also
> provide a image of the stiched images.
Brian,
Unless you're going through the WMS dispatcher, msDrawMap will fudge
and adjust the spatial extents of your map in order to preserve a 1:1
pixel aspect ratio. Look for the calls to msAdjustExtent.
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com/news
