Fix for bug #1629
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Fri Feb 3 06:50:48 EST 2006
I think we need to setup a server that will check out the sources
every night from cvs and will build them along with performing the
tests. The report would then be mailed to the mapserver-dev.
This central server then would have a standard environment that could
be replicated by the interested parties on their workstations if they
wanted to setup automated tests privately.
There could also be many different builds with different versions of
gdal, proj, with or without wms, etc. Should we make this an rfc,
maybe?
Regards,
Umberto
On 2/2/06, Sean Gillies <sgillies at frii.com> wrote:
> >> At the end of 2005, I committed a PostGIS DB makefile to mapserver/
> >> tests/makefile_postgis. The Python unit tests use this fixture.
> > Sean,
> > I just tried it and I see it depends on user postgres existing.  I'm
> > not saying this is a bad assumption, but I will suggest it is exactly
> > these sort of environment differences that make RDBMS based
> > autotesting difficult.
> Agreed. At least it's a start.
> Sean
