nonsquare pixels (was: Questions about extents and projections)
Brian Peschel
brianp at OCCINC.COM
Fri Feb 3 14:43:24 EST 2006
Sean Gillies wrote:
> Brian,
> Unless you're going through the WMS dispatcher, msDrawMap will fudge
> and adjust the spatial extents of your map in order to preserve a 1:1
> pixel aspect ratio. Look for the calls to msAdjustExtent.
> Sean
Well, I am not using the WMS dispatcher, so I see in msPrepareImage()
where the extents are changing for the 'fudge'. I do want non-square
pixels. So, I guessed that if I call:
msSetConfigOption(map, "MS_NONSQUARE", "YES");
before msDrawMap() I would get the exact extent I requested. However,
the extents are still changing, so I am missing another spot where the
extents are changing.
My extent before calling msDrawMap is
EXTENT -113.981498074503 50.7247102624229 -113.961752952407
50.7319757375771
my extent after the call is:
EXTENT -113.981498074503 50.7226042699327 -113.961752952407
50.7340817300673
whether I make the call to msSetConfigOoption() or not (I am using
msSaveMap() before and after the call to msDrawMap() to get the
extents). My image is 609x354 pixels (width x height).
My resulting images are also blank (just the background color from my
map file).
I am also running mapserver 4.6.2. I see that 4.8.0 is out. Would
upgrading help here?
