Objects exposed to SWIG interface
Tamas Szekeres szekeres.tamas at FREEMAIL.HU
Thu Feb 9 19:26:50 EST 2006
Sean,
I think not all of the developers are interested in SWIG so others should
undertake to make the revision. I you don't mind i would try to locate the
items to be supressed but you will have to commit the necessary changes.
Best Regards
Tamas
On Thu, 9 Feb 2006 16:24:55 -0700, Sean Gillies <sgillies at FRII.COM> wrote:
>On Feb 9, 2006, at 3:18 PM, Tamas Szekeres wrote:
>> Hi,
>> Is it intentional exposing some objects like:
>> DBFInfo
>> layerVTable
>> FilterEncodingNode
>> SVGObj
>> to the SWIG interface?
>> The documentation doesn't reflect theese changes.
>> Tamas Szekeres
>Tamas,
>SWIG is greedy by nature, which means that every new struct (or
>struct member) developers add to important headers gets picked up
>unless explicitly ignored.
>Part of our problem is disorganized headers. A map_objects.h (name it
>what you will) header could help us collect only the structs that we
>intend to expose as mapscript classes. The other part of the problem
>is the lack of awareness among developers about SWIG issues. I have
>not been able to make the time to keep up the addition of new struct
>members and make the judgement of whether or not they are intended
>for use with mapscript.
>cheers,
>Sean
>Sean Gillies
>sgillies at frii dot com
>http://zcologia.com/news
