Issue #1664: Unit Test support for mapserver
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Tue Feb 14 11:23:10 EST 2006
I have opened issue #1664 to track comments, feedback and of course
criticisms on the much needed (IMHO) addition of unit tests to
mapserver.
Unit tests are a completely automated way of testing code, which
should improve the development process, the code quality and the
developers' confidence in making changes to the code. I now use them
in almost every project I am involved and I find them invaluable. Go
and check out some unit tests advocacy here:
http://www.junit.org
For unit testing mapserver I have decided to use Cunit (version 2.0.x
from http://cunit.sf.net). Unit tests are located under the cunit
directory and must be compiled in pretty much the same way a mapscript
extension would. Build and running instructions are detailed in
bugzilla.
Please note that you need to install CUnit on your computer before you
can use it. I am currently using 2.0 on gentoo x86.
The unit tests I have implemented so far only test the connectin
pooling functions and to activate them you need to configure using the
--with-threads argument.
Last but not least I am working on a continuos integration project (a
la Cruise Control).
Let me know what you think and let's get this into cvs HEAD!
Umberto
