Issue #1664: Unit Test support for mapserver
Sean Gillies
sgillies at FRII.COM
Tue Feb 14 14:51:15 EST 2006
On Feb 14, 2006, at 9:23 AM, Umberto Nicoletti wrote:
> I have opened issue #1664 to track comments, feedback and of course
> criticisms on the much needed (IMHO) addition of unit tests to
> mapserver.
> Unit tests are a completely automated way of testing code, which
> should improve the development process, the code quality and the
> developers' confidence in making changes to the code. I now use them
> in almost every project I am involved and I find them invaluable. Go
> and check out some unit tests advocacy here:
> http://www.junit.org
> For unit testing mapserver I have decided to use Cunit (version 2.0.x
> from http://cunit.sf.net). Unit tests are located under the cunit
> directory and must be compiled in pretty much the same way a mapscript
> extension would. Build and running instructions are detailed in
> bugzilla.
> Please note that you need to install CUnit on your computer before you
> can use it. I am currently using 2.0 on gentoo x86.
> The unit tests I have implemented so far only test the connectin
> pooling functions and to activate them you need to configure using the
> --with-threads argument.
> Last but not least I am working on a continuos integration project (a
> la Cruise Control).
> Let me know what you think and let's get this into cvs HEAD!
> Umberto
I had not yet heard of cunit. Seems pretty cool. IMO, this could be
generally better, and more direct, than the unit tests under
mapscript/python. We've all got C compilers, so no one can complain
about how they don't have Python. On the other hand, it doesn't
exercise the C#, Java, or Python bindings at all, so it isn't a
complete replacement for the Python test suite (or a similar Java
suite).
Like Frank suggests, write up an RFC. I'm in support of the idea, and
I'm sure others can also be convinced of its utility.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com/news
