[WFS] Set max features to 0
Steve Lime
steve.lime at DNR.STATE.MN.US
Thu Feb 16 02:19:57 EST 2006
Maxfeatures was introduced as a rendering parameter (works great when data are sorted by area for interest), but has taken on special meaning in other circumstances. We'd probably have to introduce another DUMP state... DUMP FALSE would exclude the DescribeFeatureType output I imagine.
If you guys file a bug we can hack something together in 4.9 for you to test...
Steve
>>> Paul Ramsey <pramsey at refractions.net> 02/15/06 11:09 PM >>>
Perhaps... the intent is to have access to DescribeFeatureType (in
order to compose valid SLD) while not allowing GetFeatures to return
any features (to protect the actual feature sources). All hail the
WMS/SLD combination, neutered without partial WFS access!
P
On 15-Feb-06, at 8:55 PM, Steve Lime wrote:
> Clint: Perhaps I don't understand the question, but doesn't setting
> DUMP FALSE for a given layer get you this? That should keep WMS
> GetFeature and any WFS request from returning feature information,
> yet allow maps to be made.
> Steve
>>>> Clint Johnson <cjohnson at REFRACTIONS.NET> 02/15/06 7:00 PM >>>
> Hi guys,
> Is it possible to disable a layer's contents from appearing in a
> GetFeature WFS request in terms of a mapping file setting? If not,
> then
> can you give any advice reguaring where I can add such functionality
> into the mapserver source code?
> I essentially want to have a mechanism where I "protect my data"; that
> is, where a complete graphical representation of my data (aka map) can
> be viewed via a GetMap WMS request, yet be private/encapsulated by
> means
> of hidden to WFS request (in terms of not returning any features for a
> WFS request). And selective in the sense that this functionality
> can be
> applied on a per layer basis without having to completely disable WFS
> altogether.
> I've looked at the mapserver source code (all occurrences of
> MAXFEATURES/maxfeatures) and I see a lot of checks for >0 -- which
> reaffirms my observation that "MAXFEATURES 0" is the same as not
> specifying MAXFEATURES at all. My guess is that anything less than 1
> (and by default -1) is being used denote MAXFEATURES as being not set.
> Thanks,
> Clint
