[WFS] Set max features to 0
Bart van den Eijnden
bartvde at XS4ALL.NL
Thu Feb 16 02:35:15 EST 2006
There is already a wfs_maxfeatures METADATA which could serve this
purpose, and which can be used to limit the features returned by a WFS
server-side.
Are you guys trying MAXFEATURES or wfs_maxfeatures?
Best regards,
Bart
> Maxfeatures was introduced as a rendering parameter (works great when data
> are sorted by area for interest), but has taken on special meaning in
> other circumstances. We'd probably have to introduce another DUMP state...
> DUMP FALSE would exclude the DescribeFeatureType output I imagine.
> If you guys file a bug we can hack something together in 4.9 for you to
> test...
> Steve
>>>> Paul Ramsey <pramsey at refractions.net> 02/15/06 11:09 PM >>>
> Perhaps... the intent is to have access to DescribeFeatureType (in
> order to compose valid SLD) while not allowing GetFeatures to return
> any features (to protect the actual feature sources). All hail the
> WMS/SLD combination, neutered without partial WFS access!
> P
> On 15-Feb-06, at 8:55 PM, Steve Lime wrote:
>> Clint: Perhaps I don't understand the question, but doesn't setting
>> DUMP FALSE for a given layer get you this? That should keep WMS
>> GetFeature and any WFS request from returning feature information,
>> yet allow maps to be made.
>> Steve
>>>>> Clint Johnson <cjohnson at REFRACTIONS.NET> 02/15/06 7:00 PM >>>
>> Hi guys,
>> Is it possible to disable a layer's contents from appearing in a
>> GetFeature WFS request in terms of a mapping file setting? If not,
>> then
>> can you give any advice reguaring where I can add such functionality
>> into the mapserver source code?
>> I essentially want to have a mechanism where I "protect my data"; that
>> is, where a complete graphical representation of my data (aka map) can
>> be viewed via a GetMap WMS request, yet be private/encapsulated by
>> means
>> of hidden to WFS request (in terms of not returning any features for a
>> WFS request). And selective in the sense that this functionality
>> can be
>> applied on a per layer basis without having to completely disable WFS
>> altogether.
>> I've looked at the mapserver source code (all occurrences of
>> MAXFEATURES/maxfeatures) and I see a lot of checks for >0 -- which
>> reaffirms my observation that "MAXFEATURES 0" is the same as not
>> specifying MAXFEATURES at all. My guess is that anything less than 1
>> (and by default -1) is being used denote MAXFEATURES as being not set.
>> Thanks,
>> Clint
