[WFS] Set max features to 0
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Thu Feb 16 11:32:19 EST 2006
I don't see any obvious side effect for setting the
wfs_maxfeatures=0. The only thing that needed to be documented is that
when you do a wfs query and use the MAXFEATURES parameter (allowed
values start with 1), It might end up retruning nothing if the
wfs_maxfeatures is set to 0.
Brock Anderson wrote:
> I think wfs_maxfeatures would work if it allowed a value of 0, but it
> appears that 0 is essentially the same as not setting wfs_maxfeatures.
> wfs_maxfeatures > 0 works as expected (limiting the number of features
> returned by getFeature).
> Is there a reason we don't allow wfs_maxfeatures = 0? Would making that
> option available have other side effects?
> Brock
> Bart van den Eijnden wrote:
>> There is already a wfs_maxfeatures METADATA which could serve this
>> purpose, and which can be used to limit the features returned by a WFS
>> server-side.
>> Are you guys trying MAXFEATURES or wfs_maxfeatures?
>> Best regards,
>> Bart
>>> Maxfeatures was introduced as a rendering parameter (works great when
>>> data
>>> are sorted by area for interest), but has taken on special meaning in
>>> other circumstances. We'd probably have to introduce another DUMP
>>> state...
>>> DUMP FALSE would exclude the DescribeFeatureType output I imagine.
>>> If you guys file a bug we can hack something together in 4.9 for you to
>>> test...
>>> Steve
>>>>>> Paul Ramsey <pramsey at refractions.net> 02/15/06 11:09 PM >>>
>>> Perhaps... the intent is to have access to DescribeFeatureType (in
>>> order to compose valid SLD) while not allowing GetFeatures to return
>>> any features (to protect the actual feature sources). All hail the
>>> WMS/SLD combination, neutered without partial WFS access!
>>> P
>>> On 15-Feb-06, at 8:55 PM, Steve Lime wrote:
>>>> Clint: Perhaps I don't understand the question, but doesn't setting
>>>> DUMP FALSE for a given layer get you this? That should keep WMS
>>>> GetFeature and any WFS request from returning feature information,
>>>> yet allow maps to be made.
>>>> Steve
>>>>>>> Clint Johnson <cjohnson at REFRACTIONS.NET> 02/15/06 7:00 PM >>>
>>>> Hi guys,
>>>> Is it possible to disable a layer's contents from appearing in a
>>>> GetFeature WFS request in terms of a mapping file setting? If not,
>>>> then
>>>> can you give any advice reguaring where I can add such functionality
>>>> into the mapserver source code?
>>>> I essentially want to have a mechanism where I "protect my data"; that
>>>> is, where a complete graphical representation of my data (aka map) can
>>>> be viewed via a GetMap WMS request, yet be private/encapsulated by
>>>> means
>>>> of hidden to WFS request (in terms of not returning any features for a
>>>> WFS request). And selective in the sense that this functionality
>>>> can be
>>>> applied on a per layer basis without having to completely disable WFS
>>>> altogether.
>>>> I've looked at the mapserver source code (all occurrences of
>>>> MAXFEATURES/maxfeatures) and I see a lot of checks for >0 -- which
>>>> reaffirms my observation that "MAXFEATURES 0" is the same as not
>>>> specifying MAXFEATURES at all. My guess is that anything less than 1
>>>> (and by default -1) is being used denote MAXFEATURES as being not set.
>>>> Thanks,
>>>> Clint
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
