[WFS] Set max features to 0
Brock Anderson
banders at REFRACTIONS.NET
Thu Feb 16 11:18:55 EST 2006
I think wfs_maxfeatures would work if it allowed a value of 0, but it
appears that 0 is essentially the same as not setting wfs_maxfeatures.
wfs_maxfeatures > 0 works as expected (limiting the number of features
returned by getFeature).
Is there a reason we don't allow wfs_maxfeatures = 0? Would making that
option available have other side effects?
Brock
Bart van den Eijnden wrote:
>There is already a wfs_maxfeatures METADATA which could serve this
>purpose, and which can be used to limit the features returned by a WFS
>server-side.
>Are you guys trying MAXFEATURES or wfs_maxfeatures?
>Best regards,
>Bart
>>Maxfeatures was introduced as a rendering parameter (works great when data
>>are sorted by area for interest), but has taken on special meaning in
>>other circumstances. We'd probably have to introduce another DUMP state...
>>DUMP FALSE would exclude the DescribeFeatureType output I imagine.
>>If you guys file a bug we can hack something together in 4.9 for you to
>>test...
>>Steve
>>>>>Paul Ramsey <pramsey at refractions.net> 02/15/06 11:09 PM >>>
>>Perhaps... the intent is to have access to DescribeFeatureType (in
>>order to compose valid SLD) while not allowing GetFeatures to return
>>any features (to protect the actual feature sources). All hail the
>>WMS/SLD combination, neutered without partial WFS access!
>>P
>>On 15-Feb-06, at 8:55 PM, Steve Lime wrote:
>>>Clint: Perhaps I don't understand the question, but doesn't setting
>>>DUMP FALSE for a given layer get you this? That should keep WMS
>>>GetFeature and any WFS request from returning feature information,
>>>yet allow maps to be made.
>>>Steve
>>>>>>Clint Johnson <cjohnson at REFRACTIONS.NET> 02/15/06 7:00 PM >>>
>>>Hi guys,
>>>Is it possible to disable a layer's contents from appearing in a
>>>GetFeature WFS request in terms of a mapping file setting? If not,
>>>then
>>>can you give any advice reguaring where I can add such functionality
>>>into the mapserver source code?
>>>I essentially want to have a mechanism where I "protect my data"; that
>>>is, where a complete graphical representation of my data (aka map) can
>>>be viewed via a GetMap WMS request, yet be private/encapsulated by
>>>means
>>>of hidden to WFS request (in terms of not returning any features for a
>>>WFS request). And selective in the sense that this functionality
>>>can be
>>>applied on a per layer basis without having to completely disable WFS
>>>altogether.
>>>I've looked at the mapserver source code (all occurrences of
>>>MAXFEATURES/maxfeatures) and I see a lot of checks for >0 -- which
>>>reaffirms my observation that "MAXFEATURES 0" is the same as not
>>>specifying MAXFEATURES at all. My guess is that anything less than 1
>>>(and by default -1) is being used denote MAXFEATURES as being not set.
>>>Thanks,
>>>Clint
