[WFS] Set max features to 0
Daniel Morissette
dmorissette at DMSOLUTIONS.CA
Thu Feb 16 09:30:51 EST 2006
We've had discussions about similar needs a few times in the past but
never really settled on a final plan of action. There are two bugs
documenting the previous discussions:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=300
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=337
Daniel
Steve Lime wrote:
> Maxfeatures was introduced as a rendering parameter (works great when data are sorted by area for interest), but has taken on special meaning in other circumstances. We'd probably have to introduce another DUMP state... DUMP FALSE would exclude the DescribeFeatureType output I imagine.
> If you guys file a bug we can hack something together in 4.9 for you to test...
> Steve
>>>>Paul Ramsey <pramsey at refractions.net> 02/15/06 11:09 PM >>>
> Perhaps... the intent is to have access to DescribeFeatureType (in
> order to compose valid SLD) while not allowing GetFeatures to return
> any features (to protect the actual feature sources). All hail the
> WMS/SLD combination, neutered without partial WFS access!
> P
> On 15-Feb-06, at 8:55 PM, Steve Lime wrote:
>>Clint: Perhaps I don't understand the question, but doesn't setting
>>DUMP FALSE for a given layer get you this? That should keep WMS
>>GetFeature and any WFS request from returning feature information,
>>yet allow maps to be made.
>>Steve
>>>>>Clint Johnson <cjohnson at REFRACTIONS.NET> 02/15/06 7:00 PM >>>
>>Hi guys,
>>Is it possible to disable a layer's contents from appearing in a
>>GetFeature WFS request in terms of a mapping file setting? If not,
>>then
>>can you give any advice reguaring where I can add such functionality
>>into the mapserver source code?
>>I essentially want to have a mechanism where I "protect my data"; that
>>is, where a complete graphical representation of my data (aka map) can
>>be viewed via a GetMap WMS request, yet be private/encapsulated by
>>means
>>of hidden to WFS request (in terms of not returning any features for a
>>WFS request). And selective in the sense that this functionality
>>can be
>>applied on a per layer basis without having to completely disable WFS
>>altogether.
>>I've looked at the mapserver source code (all occurrences of
>>MAXFEATURES/maxfeatures) and I see a lot of checks for >0 -- which
>>reaffirms my observation that "MAXFEATURES 0" is the same as not
>>specifying MAXFEATURES at all. My guess is that anything less than 1
>>(and by default -1) is being used denote MAXFEATURES as being not set.
>>Thanks,
>>Clint
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
