Issue #1664: Unit Test support for mapserver
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Thu Feb 16 09:10:09 EST 2006
I am trying to add an rfc, could someone enable rfc editing on the
plone site for my account (unicoletti) or explain how to write one?
Regards,
Umberto
On 2/15/06, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> Frank,
> first of all thanks for your comments.
> On 2/14/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> > Umberto Nicoletti wrote:
> > > 'Course I am, as a matter of facts your tests are functional tests (a
> > > rather different beast from unit tests), while Sean's are unit tests,
> > > but for python Mapscript.
> > Umberto,
> > OK, cool.
> > > The unit tests I am introducing can go deeper and test the intimate of
> > > mapserver's code. Also unit tests can test a very limited and well
> > > defined subset of code, making memory leaks/memory
> > > misbehaviours/threading issue easier to spot. For instance I have
> > > written unit tests for the connection pooling which is not covered by
> > > Sean's tests because connection pooling functions are not exposed by
> > > mapscript and neither by yours.
> > I think running valgrind on shp2img or mapserv sessions can
> > identify most memory leaks. You are quite right that none of the
> > existing tests address pooling, or threading issues and it may be
> > challenging to do this at any level other than the C API (as you
> > suggest).
> > > IMHO it is not the case I have to argue in favour of unit tests, but
> > > quite the contrary, as the beneficial effects of unit testing seem
> > > pretty obvious to me (and to anybody who's ever used them).
> > I'm not arguing that there is no benefit to unit tests, and I have
> > used them. But if C level unit tests are to reach anything near their
> > full value, it is necessary to get others involved in extending them
> > and running them.
> Agreed.
> IMO Unit testing is not an opt-in, but a programming approach that
> must be used by all developers, that is a requirement.
> This is a clear cut case (to quote Tarantino's Jackie Brown) in my
> mind: either unit tests get into the repository AND EVERYBODY adopts
> them or they don't get into the repository at all.
> > > The reasons are:
> > > - better code
> > > - safer modifications
> > > - more confidence
> > > - regression testing
> > > - automation of repetitive tasks
> > > - integration in the build process
> I forgot to add the documentation value that unit tests add to existing code.
> > I don't see that the above items require another testing
> > mechanism with the possible exception of things that cannot
> > practically be unittested via the python mapscript tests, or
> > functionally tested via msautotest.
> Unit tests do not replace functional testing, rather functional tests
> complete unit tests.
> > > See for instance bug 1629: if we had unit tests we could have
> > > committed the modifications to 4.8.1 already without having to recall
> > > why in the first we made those changes in the first place.
> > I have briefly reviewed Bug 1629 and I cannot see why a python
> > mapscript or msautotest test item would have been inadequate
> > to handle it. Of course, there isn't any such test for PostGIS
> > support in mapserver. But we don't need a new approach, we just
> > need to more fully fill out the existing approach.
> Of course you can do it with mapscript or msautotest, but that
> requires a postgis setup which not everybody has available.
> With C unit tests you can just test the query composer function and
> verify that the string it produces is the one you are expecting,
> dropping entirely the need for a full fledged build environment.
> Of course this kind of testing requires refactoring of existing code
> to make it more easily testable.
> For an example see the two methods I have added to the connection pooling apis:
> int msConnPoolGetConnectionCount();
> int msConnPoolGetConnectionMax();
> Best regards,
> Umberto
> > >> Currently it seems we have roughly as many test suite mechanisms as we
> > >> have developers interested in using and supporting them.
> > >> I imagine you ought to write an RFC proposal on your unittest approach
> > >> before it is integrated into MapServer.
> > > If that is necessary I'll do it, but I'd better code than write.
> > I'm sure we would all rather code than write RFCs, but we decided to
> > require RFCs for a certain class of changes in MapServer to ensure
> > we have coherent progress, avoid bloat, and fine tune approaches to
> > new features before they we are committed to them.
> > You can certainly maintain a test harnass on your own, but if you
> > want it in the tree I think it deserves an RFC. As per ms-rfc-1,
> > Steve is the final arbiter of what does or does not need an RFC.
> > Please don't consider my feedback as saying I don't want C unit
> > tests. If there is a good case for why we need them instead of
> > python unit tests, and if you are willing to do the work to establish
> > them then I'm keen on it.
> > Best regards,
> > I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> > light and sound - activate the windows | http://pobox.com/~warmerdam
> > and watch the world go round - Rush | Geospatial Programmer for Rent
