OracleSpatial 10i GetExtent slow
Hallgren Johan E
jhhal at WMDATA.COM
Thu Feb 23 08:32:48 EST 2006
I have a table with about a million polygon records.
When I will do a getExtent it takes looong time. Five to ten minutes. I
can see it uses the "SELECT SDO_AGGR_MBR(SHAPE) AS GEOM FROM (SELECT
SHAPE FROM SJ_large_sdo);" and it seams as it have to run a full table
scan.
I'm using mapserver-4.8.1
Oracle 10.1 (windows Server)
MapFile:
CONNECTION "wmgis/xxx at wmsi1394"
CONNECTIONTYPE oraclespatial
DATA "shape FROM (SELECT OBJECTID, SHAPE, KKOD FROM SJ_large_sdo) USING
UNIQUE OBJECTID VERSION 10g"
Is there a way to get the extent faster? Don't OracleSpatial have some
metadata with extent?
Could I store the extent for the layer in the MapFile?
I'm using MapScript to build the logics
Thanks in advance
/Johan
___________________________________
Johan Hallgren
WM-data
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel: 023-844 65 (int: +46-2384465)
Mobil: 070-588 44 28 (int: +46-705884428)
johan.e.hallgren at wmdata.com
<BLOCKED::mailto:johan.e.hallgren at wmdata.com>
http://www.wmdata.se <BLOCKED::http://www.wmdata.se>
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20060223/5de5995b/attachment.html
