Curved Labels?
Benj Carson benjcarson+mapserver at DIGITALJUNKIES.CA
Thu Feb 23 19:40:52 EST 2006
Steve,
I'm certainly not the expert here, but my guess would be that you need to
regenerate the parser.  Provided you have flex installed, a make clean
should do the trick, as Bill mentioned.
Benj
On Thursday 23 February 2006 16:16, Stephen Woodbridge wrote:
> Hi Steve, Benj,
> I just checked out the current CVS, and wanted to try out the curved
> labels. created:
>         LABEL
>           ANGLE FOLLOW
>           FONT "arial"
>           TYPE TRUETYPE
>           POSITION CC
>           SIZE 7
>           BUFFER 4
>           COLOR 0 0 0
>           OUTLINECOLOR 245 245 231
>           ANTIALIAS TRUE
>           PARTIALS FALSE
>           MINDISTANCE 250
>           MINFEATURESIZE 10
>         END
> and tried it on a line layer, but I get the following error:
> getSymbol(): Symbol definition error. Parsing error near (FOLLOW):(line
> 1366)
> Do I need to specify a special config parameter when I build it? I seem
> to have misplaced the special incantations  :)
> -Steve W.
