Curved Labels?
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Feb 23 19:46:49 EST 2006
Thanks guys,
That was it, I had to manually rm maplexer.c mapparser.c to get them to
be rebuilt, there is not make target that does this.
-Steve W
Benj Carson wrote:
> Steve,
> I'm certainly not the expert here, but my guess would be that you need to
> regenerate the parser. Provided you have flex installed, a make clean
> should do the trick, as Bill mentioned.
> Benj
> On Thursday 23 February 2006 16:16, Stephen Woodbridge wrote:
>>Hi Steve, Benj,
>>I just checked out the current CVS, and wanted to try out the curved
>>labels. created:
>> LABEL
>> ANGLE FOLLOW
>> FONT "arial"
>> TYPE TRUETYPE
>> POSITION CC
>> SIZE 7
>> BUFFER 4
>> COLOR 0 0 0
>> OUTLINECOLOR 245 245 231
>> ANTIALIAS TRUE
>> PARTIALS FALSE
>> MINDISTANCE 250
>> MINFEATURESIZE 10
>> END
>>and tried it on a line layer, but I get the following error:
>>getSymbol(): Symbol definition error. Parsing error near (FOLLOW):(line
>>1366)
>>Do I need to specify a special config parameter when I build it? I seem
>>to have misplaced the special incantations :)
>>-Steve W.
