RFC 13 : SOS support
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Fri Feb 24 10:30:16 EST 2006
Frank Warmerdam wrote:
> Stephen Woodbridge wrote:
>> Assefa,
>> While I don't have a vote on this, I am concerned about integrating
>> this with mapserver from the point of view that it did not seem to be
>> a feature that was useful to the community at large. In fact it seemed
>> to be a custom extension that only 1 or 2 people might use, but maybe
>> I don't remember that point all that well.
>> Anyway, my concern is that if it is added to the core mapserver, even
>> with #ifdef blocks, think there is some obligation of the developers
>> to build and test these features when things change, additional over
>> head of documentation, training, beta testing, bug fixes, etc. This
>> all adds to the overhead of development and maintenance and slows down
>> the process.
>> After reading the RFC again and looking at the example URL, it is not
>> obvious that this has anything to do directly with serving maps. It
>> looks like it is just using the existing OGC infrastructure in the
>> mapserver code base. Granted mapserver does queries and this looks
>> like it is doing queries, but then so does every database.
>> Can the sensor observations be rendered as a layer?
>> Will you be able to style them like other layers?
>> So I think it should be looked at in terms of the costs versus the
>> benefits to the general community. I thought in the original
>> presentation of the RFC there was an option to build this as a
>> separate project dependent on but separate to mapserver which seems to
>> be a better option from my perspective, but maybe I am not
>> understanding the full scope of the project correctly.
> Steve,
> I can see your concern, but to me the SOS support seems closely analygous
> to the WFS support. It doesn't produce a map, but it does provide another
> interface to the underlying data objects, like WFS. I see implementing
> this
> as part of a commitment within MapServer to implement OGC services that
> make
> sense in the context of MapServer.
> Because of that, I'm "+1".
> I would appreciate some discussion of what auto-testing is planned for the
> SOS feature. I think this is especially important since most developers
> will
> not be familiar with SOS support and how to test it manually.
> Best regards,
Frank,
I am going to update the RFC to include producing automatic testings
to fit into the msautotest structure.
Thanks for your feed back and support.
Best Regards,
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
