24 bit to 8 bit gd conversion
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Sun Feb 26 15:02:35 EST 2006
Hi There,
We were doing few tests last week on the possiblity to do 24 bit
rendering using png24 and convert the output to 8 bit at the end. The
main reason being that we had issues with the color limitation on some
of the maps we were using. And also the fact that antialising was only
available in 24bits.
We were experimenting with the gd function
gdImageCreatePaletteFromTrueColor(img, 0, 256); to achieve that,
calling the fucntion just before the save.
It seems to give decent results, although I think we need to do more
tests and there seems to be an issue with transparencies.
The idea was that if It was a good enough, It could make it into
something like an outputformat option.
What do you think in general about this issue ?
Thanks
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
