Fuzzy brushes (was "Ready for 4.8.0-rc1?")
Paul Spencer
pspencer at DMSOLUTIONS.CA
Tue Jan 3 10:23:37 EST 2006
Cool. Lemme know if you've updated anything in cvs and I'll get
Assefa to build me a new binary so I can test it against our map
files :)
Cheers
Paul
On 2-Jan-06, at 11:16 PM, Steve Lime wrote:
> Paul (et al.): I've played around with these a ton recently. I did
> change the brush creation algorithm to more closely approximate
> Photoshop or Gimp and the brushes look quite nice. The stair steps
> still persist at some angles. I'm convinced it is a problem in GD.
> Brushes w/alpha transparency seem to suffer from aggregation
> effects of repeated alpha blending. For example, you can create a
> circular brush with alpha=64 (50% transparent) and if you draw with
> it the resulting line is *much* darker than you would expect. This
> has an unfuzzing effect. As as result the "jaggies" you see in
> unantialiased lines persist. Off to poke around in GD now.
> A work in progress...
> Steve
>>>> Paul Spencer <pspencer at DMSOLUTIONS.CA> 12/22/05 6:54 AM >>>
> Steve,
> I have a question about fuzzy brushes. Your test case looks really
> good. We tried this on our tiger map file in ka-Map and the results
> are less impressive. It seems to work well for lines that are close
> to 45 degrees, but for lines that are closer to the vertical or
> horizontal, there is still a noticeable stairstep effect. Did you
> try other angles on the line? From what you said, my understanding
> is that this could be affected by the default hardness that you have
> chosen?
> Cheers
> Paul
> On 22-Dec-05, at 12:08 AM, Daniel Morissette wrote:
>> Our planned date for 4.8.0rc1 is today (Thursday Dec 22nd). Are we
>> good to go? Did you still have work to do on the fuzzy brushes Steve?
>> Daniel
>> Daniel Morissette dmorissette at dmsolutions.ca
>> DM Solutions Group http://www.dmsolutions.ca/
> |Paul Spencer pspencer at dmsolutions.ca |
> |Applications & Software Development |
> |DM Solutions Group Inc http://www.dmsolutions.ca/|
