4.8.0 Release...
Daniel Morissette dmorissette at DMSOLUTIONS.CA
Fri Jan 6 15:38:51 EST 2006
Steve Lime wrote:
> Hi folks: Sean and I found a bug in the antialiasing code (single pixel lines) within GD that causes segfaults under certain circumstances. It's a problem with the way they implement clipping for aa lines. I contacted Thomas Boutell late last night and actually heard back this morning. The issue has been fixed in the upcoming GD 2.0.34 release (no date on that release).
This is just an old GD bug and it's not related to 4.8 specifically,
right? If that's not directly related to anything in 4.8 but is just a
GD bug that applies to MapServer 4.6 as well then I don't think we
should do anything specific to 4.8. Instead we could just make a patch
available that can be used in compiling MapServer (4.6 or 4.8) with the
GD fix.
> How should we handle on our end? This does not affect the fuzzy brush code.
> I was thinking about asking for a preview release of 2.0.34 and then perhaps adjusting the configure process to detect that version. The patch to fix GD is trivial so we could even offer a patched version (or the patch itself) for folks that want to use aa.
GD doesn't carry any version information anywhere (or didn't as far as I
remember) so it's really hard to detect specific versions unless new
functions were added and then we test for the new functions. Detecting a
bug fix would be even harder so I'd avoid that if possible.
I think offering a patch that can be applied to 4.8 (and 4.6?) would be
the way to go, without modifying the official release.
BTW, you released RC1 just before Xmas as planned. Are we good to
release 4.8 or should we wait a bit more? There have been at least 5 bug
fixes since RC1 so maybe we should do RC2 once everybody is ready and
branch the source tree at the same time?
Daniel
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
