antialiasing stuff
    Paul Spencer
    pspencer at DMSOLUTIONS.CA
    Fri Jan 13 15:43:54 EST 2006
cool, thanks :)  I hadn't tried it, thought I would ask first.  I've
managed to achieve almost the desired effect by jacking the hardness
to 0.95 and fixing the gd bug for 1 pixel lines since I asked so
maybe we won't end up going this route.
Cheers
Paul
PS: any chance of having a HARDNESS keyword at the style level?
On 13-Jan-06, at 2:55 PM, Steve Lime wrote:
> This should be doable "as is". Just set TRANSPARENCY ALPHA and point
> to the right image in your style or symbol definition. All the
> fuzzy brush
> support does is do this programatically.
> I believe I've tested this before using an image or two that Sean
> had created
> while fixing another bug.
> Have you tried it and it doesn't work?
> Steve
>>>> Paul Spencer <pspencer at DMSOLUTIONS.CA> 01/13/06 12:59 PM >>>
> Steve,
> what would it take to support rendering lines with custom symbols
> that have alpha transparency in them?  We would like to be able to
> make our own brushes that work in the same way that fuzzy brushes
> work, but we pre-render them and access them as symbols.  This would
> allow finer control over styling without having to tweak mapserver
> code to get the desired effect :)
> Cheers
> Paul
> |Paul Spencer                           pspencer at dmsolutions.ca   |
> |Applications & Software Development                              |
> |DM Solutions Group Inc                 http://www.dmsolutions.ca/|
