PostGIS Bug 1587 (was Release Candidate 3)
Jerry Pisk
jerry.pisk at GMAIL.COM
Thu Jan 19 12:35:55 EST 2006
This is the client machine bit order, is there really a need to store
it locally for each layer? You really only need to find a way to
initialize the variable before any PostGIS layers are open. Even the
existing code would work fine, there will be multiple writes to the
global variable but they will all write the exact same value to it so
it would not matter in which order they come in relation to reads from
it.
Jerry
On 1/19/06, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> A big thanks from Italy!
> So is it gonna make it for 4.8?
> Regards,
> Umberto
> On 1/19/06, Sean Gillies <sgillies at frii.com> wrote:
> > I just applied Umberto's patch to 4.8 and python/tests/cases/
> > pgtest.py runs just fine. Without this patch, it is possible that
> > users could get into trouble connecting to separate databases from
> > the same map if byte order differs between the DB platforms.
> > Sean
> > On Jan 19, 2006, at 8:10 AM, Steve Lime wrote:
> > > I see no one from Refractions has commented one way or the other.
> > > It would =
> > > be nice to get Paul or one of his technical folks to at least bless
> > > the =
> > > patch before modifying their module. I think someone from that
> > > group still =
> > > hangs out here occationally...
> > > Steve
> > >>>> Umberto Nicoletti <umberto.nicoletti at GMAIL.COM> 01/19/06 8:20 AM
> > > Hi,
> > > do you think this bug could be fixed before 4.8 gets out?
> > > http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=3D1587
> > > It's been there for a month and it looks like a trivial patch to me. I
> > > have tested the patch on 4.6.2.
> > > Best regards,
> > > Umberto
