PostGIS Bug 1587 (was Release Candidate 3)
Sean Gillies
sgillies at FRII.COM
Thu Jan 19 12:53:48 EST 2006
You're right. I'll back out the commit if you have misgivings about it.
Sean
On Jan 19, 2006, at 10:35 AM, Jerry Pisk wrote:
> This is the client machine bit order, is there really a need to store
> it locally for each layer? You really only need to find a way to
> initialize the variable before any PostGIS layers are open. Even the
> existing code would work fine, there will be multiple writes to the
> global variable but they will all write the exact same value to it so
> it would not matter in which order they come in relation to reads from
> it.
> Jerry
> On 1/19/06, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
>> A big thanks from Italy!
>> So is it gonna make it for 4.8?
>> Regards,
>> Umberto
>> On 1/19/06, Sean Gillies <sgillies at frii.com> wrote:
>>> I just applied Umberto's patch to 4.8 and python/tests/cases/
>>> pgtest.py runs just fine. Without this patch, it is possible that
>>> users could get into trouble connecting to separate databases from
>>> the same map if byte order differs between the DB platforms.
>>> Sean
>>> On Jan 19, 2006, at 8:10 AM, Steve Lime wrote:
>>>> I see no one from Refractions has commented one way or the other.
>>>> It would =3D
>>>> be nice to get Paul or one of his technical folks to at least bless
>>>> the =3D
>>>> patch before modifying their module. I think someone from that
>>>> group still =3D
>>>> hangs out here occationally...
>>>> Steve
>>>>>>> Umberto Nicoletti <umberto.nicoletti at GMAIL.COM> 01/19/06 8:20 AM
>>>> Hi,
>>>> do you think this bug could be fixed before 4.8 gets out?
>>>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=3D3D1587
>>>> It's been there for a month and it looks like a trivial patch to
>>>> me. =
> I
>>>> have tested the patch on 4.6.2.
>>>> Best regards,
>>>> Umberto
Sean Gillies
sgillies at frii dot com
http://zcologia.com/news
