Newer Swig versions...
Howard Butler hobu at IASTATE.EDU
Sun Jul 16 19:44:38 EDT 2006
I put a guard that tests for SWIG 1.3.29 in map.i, but forgot to
include SWIG 1.3.28 to fix the intarray_setitem misery.  SWIG changed
how it renamed those method names (for Python only AFAIK) in 1.3.28.
I did not make this fix in the 4.8 branch, however.
The buildkit has both 1.3.27 and 1.3.29 included, but I have been
using 1.3.27 as the default configuration (there's nothing that
limits you from changing the nmake.opt to point at 1.3.29 though).
I would also note that there are some really scary optimizations that
you can use in SWIG 1.3.29 that at first glance appear useful.  I
spent a couple of hours fiddling with them that resulted in using the
current swig command that we've always been using ;)
Howard
At 6:07 PM +0200 7/12/06, Tamas Szekeres wrote:
>AFAIK the hobu's buildkit is now capable to use even the 1.3.29, and
>the previous ms4w was compiled using that kit (with 1.2.37 setting).
>The SWIG C# may result in unexpected behaviour when using earlier than 1.3.27.
>It must be noted that the SWIG guys like to issue backward
>uncompatible releases so continuously supporting the newer versions is
>a big deal ;-)
>Tamas
>2006/7/12, Steve Lime <Steve.Lime at dnr.state.mn.us>:
>>There is a 1.3.29 I think.
>>Steve
>>>>>  thomas bonfort <thomas.bonfort at GMAIL.COM> 7/12/2006 10:50:03 AM >>>
>>just my 2c
>>latest swig (1.3.28) prevents python mapscript from being properly executed:
>>ImportError: ../../build/lib.linux-i686-2.3/_mapscript.so: undefined symbol:
>>intarray_setitem
>>see also http://trac.gispython.org/projects/PCL/ticket/44
>>this is not the case with 1.3.24 (or .27 according to the previous link)
>>cheers
>>On 7/12/06, Daniel Morissette <dmorissette at mapgears.com> wrote:
>>>  Steve Lime wrote:
>>>  > Hi all: Currently all distributions comming off cvs.gis.umn.edu are
>>>  being build with Swig 1.3.21. I'm just wondering what folks think about
>>>  moving to the latest versions. Has anyone played with MapScript
>>>generated by
>>>  the new version?
>>>  > Steve
>>>  I haven't played with SWIG much lately so I do not have an opinion on
>>>  the upgrade, but I think we should generate the 4.8.4 release before
>>>  doing the switch just to be safe.
>>>  BTW, I will prepare the 4.8.4 source for the release later today and
>>>  will let you know when it's ready to package.
>>>  Daniel
>>>  Daniel Morissette
>>>  http://www.mapgears.com/
