RFC 19: style and label attribute binding...
    Stephen Woodbridge
    woodbri at SWOODBRIDGE.COM
    Thu Jun  8 09:52:53 EDT 2006
Steve Lime wrote:
> Hi all: I put some ideas to paper base on the thread yesterday as RFC
> 19:
> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-19
> The change really isn't that bad, but is probably a 5.0 modification
> (which could be our next release).
> Steve
Steve,
This sounds like a very straight forward implementation that is easily
extensible to other attributes. It looks like bindings will only be
implemented within the layer/style objects, but not class objects which
I assume is because those fields that could be bound are all deprecated
and should be in style style.
Do you have a list of bindings that you plan to implement in this
initial implementation? Are there items people might reasonably think
should have bindings that you plan to NOT implement for any reason? Like
in the CLASS object.
Backwards compatibility:
I think is a more rhetorical question that needs to be discussed.
On the one hand, it seems it would not be difficult to to maintain the
existing angleitem, xxxitems fields and mapscript interfaces, but to
change them to use the new implementation in addition to adding the new
interfaces you describe and thus NOT brake Backwards Compatibility.
On the other hand, IF we are going to brake Backwards Compatibility,
then I think we should clean up a lot of stuff and remove the deprecated
items that make the mapfile and mapscript complex because there are
multiple places that key words can be used, but the code only works for
some new features if you use one of the items and not the other, like
anti-aliasing requires you to use the style object and not the class
object to define you styling. I think clean up mapscript and the mapfile
while painful for some users would have the benefit of a cleaner,
smaller, more rational implementation.
This also raises in my mind the need for a clearly stated feature
supported/deprecated/removal policy and an old version support policy. I
think we have most of that in that we try to act in consistent manner
from release to release and maintain backwards compatibility except on
major releases. But we do not seem to have a policy on feature
deprecation and obsolescence and removal. This is probably because we
rarely if ever remove features.
-SteveW
