RFC 19: style and label attribute binding...
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Thu Jun 8 12:23:11 EDT 2006
>>> Stephen Woodbridge <woodbri at swoodbridge.com> 6/8/2006 8:52:53 AM >>>
Steve Lime wrote:
> Hi all: I put some ideas to paper base on the thread yesterday as RFC
> 19:
> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-19
> The change really isn't that bad, but is probably a 5.0 modification
> (which could be our next release).
> Steve
> Steve,
> This sounds like a very straight forward implementation that is easily
> extensible to other attributes. It looks like bindings will only be
> implemented within the layer/style objects, but not class objects which
> I assume is because those fields that could be bound are all deprecated
> and should be in style style.
Those properties are surrogate for styles anyway so for a mapfile you could
support:
CLASS
SIZE 'mySizeItem'
END
You can't set $class->{size} from MapScript anyway so in that environment
it's not an issue.
> Do you have a list of bindings that you plan to implement in this
> initial implementation? Are there items people might reasonably think
> should have bindings that you plan to NOT implement for any reason? Like
> in the CLASS object.
I'll have to create a list. I had not planned on supporting any of the boolean
parameters (e.g. ANTIALIAS), but just about everything else would be fair game.
> Backwards compatibility:
> I think is a more rhetorical question that needs to be discussed.
> On the one hand, it seems it would not be difficult to to maintain the
> existing angleitem, xxxitems fields and mapscript interfaces, but to
> change them to use the new implementation in addition to adding the new
> interfaces you describe and thus NOT brake Backwards Compatibility.
It would not be difficult within a mapfile, but would be difficult, if not impossible,
within MapScript. Something like $style->{angleitem} can not be translated into
$style->setBinding(...) without typemaps so it's not worth it.
> On the other hand, IF we are going to brake Backwards Compatibility,
> then I think we should clean up a lot of stuff and remove the deprecated
> items that make the mapfile and mapscript complex because there are
> multiple places that key words can be used, but the code only works for
> some new features if you use one of the items and not the other, like
> anti-aliasing requires you to use the style object and not the class
> object to define you styling. I think clean up mapscript and the mapfile
> while painful for some users would have the benefit of a cleaner,
> smaller, more rational implementation.
In this particular case I think some breakage is inevitable, but remember these are
lightly used features so the risks are relatively small.
> This also raises in my mind the need for a clearly stated feature
> supported/deprecated/removal policy and an old version support policy. I
> think we have most of that in that we try to act in consistent manner
> from release to release and maintain backwards compatibility except on
> major releases. But we do not seem to have a policy on feature
> deprecation and obsolescence and removal. This is probably because we
> rarely if ever remove features.
I'm all for consistency in point releases but major releases give us the opportunity
to clean things up a bit. Even in those cases disruption should be minimized. In this
case I would advocate a clean up...
> -SteveW
Steve
