RFC 19: style and label attribute binding...
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Thu Jun 8 12:13:53 EDT 2006
If you bind all the attributes (or at least those that make sense) then that is a reasonable assumption since there are a fixed number
of properties for styles and labels. Deciding to bind or not is a runtime decision.
Steve
>>> Paul Spencer <pspencer at DMSOLUTIONS.CA> 6/8/2006 10:05:15 AM >>>
Steve,
I'm not sure if I interpreted this correctly, but are you proposing
to have a fixed number of style and label bindings pre-determined at
compile time? I thought the trend was to move away from compiled-in-
limits? Would it be terribly difficult to use dynamic allocation for
these things? I suspect that if you choose a reasonable limit, it
won't be long before we start seeing people wanting the limit increased!
Cheers
Paul
On 7-Jun-06, at 11:09 PM, Steve Lime wrote:
> Hi all: I put some ideas to paper base on the thread yesterday as
> RFC 19:
> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-19
> The change really isn't that bad, but is probably a 5.0
> modification (which could be our next release).
> Steve
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
