libxml usage
Daniel Morissette
dmorissette at MAPGEARS.COM
Fri Jun 9 16:59:06 EDT 2006
Yewondwossen Assefa wrote:
> Things that quickly comes to mind are :
> * learning curve of using the library (at least for the output part) is
> not expensive.
> * It is well supported on different platforms
> * It definitely remove all the formatting/closing tags ... concerns,
> creating an xml friendly environment
> * I have not done any performance tests but It should be slower than
> using the printf directly, although the SOS requests are returned in a
> reasonable amount of time
> * I think It makes it easier to maintain in a long term.
> Saying that, moving all the other Ows and gml services to use an xml
> library is major task. As you mentioned it will only be appropriate to
> do so if there is a major revision of the service that requires the
> rewrite of the support in Mapserver. Otherwise, It is not always easy to
> justify/fund a rewriting of a module when there are no gains in
> functionality to show for.
I don't have much to add... I agree with all of Assefa's comments.
Daniel
Daniel Morissette
http://www.mapgears.com/
