SWIG mapscript critical problems!!!
Tamas Szekeres
szekerest at GMAIL.COM
Thu Jun 22 08:39:29 EDT 2006
Umberto,
2006/6/22, Umberto Nicoletti <umberto.nicoletti at gmail.com>:
> This solution implies an API change which I don't favour. I like
> better the solution you have already implemented in csmodule.i but it
> needs to be extended to other languages and to other functions like
> insertClass, setMetadata, etc.
> Btw have you seen how the ruby people are doing it?
> http://www.swig.org/Doc1.3/Ruby.html#Ruby_nn57
1. In this case SWIGTYPE DISOWN is not usable since the behaviour
depend on the parameter. If null parameter is given for the
constructor disowning the internal memory will result in a memory
leak.
2. I wonder is DISOWN works for C# by looking a the documentations and
the swig source tree.
> > For example layerObj.map is handled internally and is solely for
> > getting the reference of the parent object.
> In Java you can't set the map reference, only get it.
Ok, i was thinking of legendObj.map for example, apologies.
> Because not all mapscript objects are properly set up: for instance
> webObj until recently did not have a constructor which invoked initWeb
> so the metadata had to be set from Java. This can be solved of course,
> but it would break backwards compatibility (API change).
I would discourage to maintain unintentionally exposed interface
elements just for retaining the backward compatibility. Users should
not create objects from scratch and add them to a parent object is it
has already been constructed during the parent object creation.
Regards,
Tamas
