Pixmap symbol scaling bug #1684: review and back porting
Jani Averbach
javerbach at EXTENDTHEREACH.COM
Thu Mar 2 11:26:03 EST 2006
Steve, there is also a second code path, when this happens.
This second path is when you are loading pixmap symbol from
symbol file. I am looking this.
BR, Jani
> -----Original Message-----
> Thanks, I'll have a look at the fix.=20
> As for backporting, if it's a bug fix and relatively benign
> (not likely to =
> much anything else) or a relative major problem then it's a
> good candidate =
> for back porting. Updating the bug, if you haven't already,
> would be a =
> good place to start. I would think this would be a candidate
> since 4.8 is =
> not behaving like 4.6...
> Steve
> >>> Jani Averbach <javerbach at EXTENDTHEREACH.COM> 03/01/06 8:18 PM >>>
> Hello,
> I fixed the bug #1684, and while I was there, I accidentally
> committed=20
> it directly to stable 4.8 branch, sorry about that.=20
> However, I reverted that change on branch-4-8.
> So if someone has time to review "mapsymbol.c: Revision
> 1.93", it would be =
> nice.
> Secondly, what is the correct procedure to propose this to be
> back ported =
> for 4.8.2?
> BR, Jani
> SRC,LLC
> SRC in Action:
> http://www.DemographicsNow.com
> Join SRC at Extend 2006 - Disruptive Technology
> June 5-7, 2006 at the Hyatt Regency, Huntington Beach, CA
> For more details, click here: http://www.extendthereach.com/extend06/
