MapServer 4.8.2
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Thu Mar 16 16:09:51 EST 2006
I would also want to add the bug
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1717
It is related to php mapscript and was causing as problems when building
it as a dll.  I have done the initial tests with the fix and Jeff is
also doing some tests. It seems to be working well on windows. I have
also asked Daniel if he could test it on Linux.
Howard Butler wrote:
> Let's release this baby.  I propose we do it Wednesday, March 15th.
> Some open bugs that might need some attention:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1705 - Symbol rotation
> leaks memory
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1684 - Pixmap SIZE
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1699 - Point Queries
> in SDE throws an error
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1702 - Shapefile
> handles getting left open in the case of bad data
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1700 - OGR tileindex
> sources always opened as shapefiles
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1683 - configure.in
> should be able to detect the Oracle "instant client" rpm distro
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1669 - msSaveMap()
> should write out TRANSPARENCY ALPHA
> There may be many others ;)  Let's clean them up and get this out the door.
> Howard
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
